Warn Or Tusk Snow Plow for Brute?
Old Nov 21, 2005 | 09:37 PM
Todd400's Avatar
Default Warn Or Tusk Snow Plow for Brute?
I got the $69 warn winch with my new brute & have been doing some research & I think Im going to go with a a warn 48" set-up or a Tusk 50" from rocky mountain, Just hoping to get some feedback from others with these plows, I want something that is built well & actually works like it should & is a true quick release system, Also interested in both of these because it appears they dont attach with u-bolts at the mounting plate, So if anyone has these let me know how you like them?? Thanks
Old Nov 22, 2005 | 06:59 PM
brokebrute's Avatar
I would go with the Tusk I did. The Tusk mount replaces your stock plastic skid plate with a smooth steel one that stays on year round. There is another plate that slides on to attach the plow to it only requires loosening and tightning 4 nuts to install or remove. The hole setup is very well built "heavy duity" and cheeper than the warn.
Old Nov 22, 2005 | 08:57 PM
InsaneApe's Avatar
Todd400, the cyclecounty plow seems pretty good but I don't know if it uses U-bolts to mount. Why don't you want a u-bolt mounted system? (ground clearance??)
Old Nov 22, 2005 | 09:04 PM
Todd400's Avatar
I like the way the warn mounts with out using u bolts, it replaces the factory skid so clearence isnt given up, Plus with the tusk or warn i would just leave the mount on year round, I will check out the c.c. thanks.
Old Nov 22, 2005 | 10:59 PM
Bigsaint's Avatar
I have the 50" Tusk Dozer, real nice set up for the money.
Old Nov 23, 2005 | 07:21 AM
brokebrute's Avatar
I like my tusk better than the cycle country I used to have.
Jeff Roper
Feb 1, 2022 11:48 AM
ylomnstr
Sep 22, 2015 12:19 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
