lectron jetting question
Old Nov 21, 2005 | 11:29 PM
DSWOLF's Avatar
Default lectron jetting question
does the jetting in this carb work whit elevation?
Old Nov 22, 2005 | 12:14 AM
BlackHawk's Avatar
The Lectron once you dial in the jetting correctly should be able to handle several thousand feet of elevation change.
Old Nov 22, 2005 | 12:57 PM
DSengineer's Avatar
Has been here a long time!
My Lectron is tuned for sea level and I can go to Sand Mtn ~4500ft and not make any changes. I have tried leaning it out sligtly at 4500 ft but it seems to be too lean. The carb does its own adjusting to a certain degree. If I get up around 6000+ ft I will give a 1/4 turn on the metering rod which takes all of about 2 minutes. No jets to carrry along or fuss with and its all done from the top side of the carb. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 22, 2005 | 02:33 PM
Scatterbrain's Avatar
Once you got it, you got it. I havnt had any to adjust anything since getting it properley tuned.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
