brute 750 mods
Old Nov 23, 2005 | 09:41 PM
roosterex's Avatar
Default brute 750 mods
I just picked up a 05 750 what are the must do mods, any known problems, I traded in a 650 rincon, as soon as i rode the brute I never looked back. any info I can get is much appreciated thanks rooster
Old Nov 24, 2005 | 12:05 AM
sam's Avatar
sam
I just got one about a month ago too. this is what ive herd and plan on doing.
first dynojet kit the brute is jetted lean from the factory and this helps a ton. I noticed it right away mine was poping
second the tires are junk from what I herd Im going for a radial prob a kenda bounty hunter or a carlisle radial badland xtr or act's
third is a cdi or a moose module
these three are a good start and if any one has any thing to add please do.
JMO
sam
Old Nov 24, 2005 | 12:52 AM
bruteforcebob's Avatar
moose module, black secondary, grease bus connectors, tie rods, either a splash guard on the factory snorkel or snorkel it, wheels and tires.
Old Nov 24, 2005 | 01:43 PM
BruteForceNewYork's Avatar
I just put the Dyna CDI on mine ......all I can say is wow what a difference...much more agressive acceleration
Old Nov 25, 2005 | 03:01 PM
hollowcd's Avatar
Sam, as far as the Dynojet kit try this first. I asked my dealer about a recall on the front needle. I then posted a message in here and they told me that there was a "technical service bulletin" on it, not a recall. In other words, the dealer knows there is a problem but he doesnt have to fix it unless you ask them. I took mine in and they had it back in two days with a new needle, problem solved, and it was free. Try that and it will save you a few bucks on the dynojet. Good luck
Old Nov 25, 2005 | 08:43 PM
rhoppy's Avatar
What exactly is a dyna cdi? Where can I get it? How much do they cost? I just got a 2006 Brute Force 750 and so far I love it. Lots of power. I hope to get bigger tires and wheels . Will this help?
Old Nov 26, 2005 | 10:12 AM
brokebrute's Avatar
http://www.dynaonline.com/english/atv_fs.htm#kawasaki
This is where you get it as far as what it does it advances the timing which makes it run much better. Tere is a post on highlifter.com that all brute owners should read about the wiring coroding mine has allready started to.
Old Nov 26, 2005 | 10:16 PM
just so you know, another thing to look into is new tie rods and ends, the cap on the back of my inner apparently popped out and filled with mud. I was riding today and had just set down a wheelie and hit the next small bump at like 5mph and there it went bam! added 400ex tie rods and ends tonight by moose... I think they will be ALOT better and stronger
Pgbama11
Jan 16, 2016 08:19 AM
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 4, 2015 05:02 PM
