NEED SOME HELP BAD
Blowed my right cv joint. took it to the local drive shaft shop and got it repaired, got it back and installed it. Now the shaft is pulling out of the differentional I got a new circlip and that didn't help. I also bought a complete shaft and cv when i put it on i can't even tighten it up without it pulling out. Im out of ideals Iam abought ready to strike a match and burn the ---- thing anybody have any trouble like this?????????????? any help would be greatly appreciated
I have smoked 2 cvs on my 04 700 and as of tonite 2 front differentials without your problem.Is your front diff smoked? if it binds up awful things happen on one side or the other just a thought.
Thanks for your help itstillruns and Idahovinnie, the differential is ok. when i put it together the first time and rode it all that happened was i seen where the shaft was out of the differential about an inch. 4 wheel drive worked ok, also when i tore it down the first time i had a really hard time getting the shaft out of the diff so im thinking like Idahovinnie maybe the shaft is to short. I would test this ideal if i could get the left side out i've tried but with no luck. I browed a slide hammer from a friend it didn't have the right ends on it keeps pulling off the yoke.I guess Iwill end up taking it to the shop, If yall have anymore ideals please post. Thanks again for your help
Different models (year) different length shafts better double check. when measuring check compressed length and uncompressed. Take care!!
On the end of the splined shaft is a groove for a snap ring,is that ring on?. To get the other side off, use a large pry bar or screwdriver stick it in between the U-joint and yoke and pry outward against frame should release with a little effort and some PB Blaster or Wd40 when you reassemble, a little anti-sieze is agood idea Good luck.
