DS650 Rev Limit?
Old Nov 25, 2005 | 08:43 PM
DSNUT's Avatar
Default DS650 Rev Limit?
I have MSD adjustable Ignition. My power peak with the HPR730 seems to be about 7300 or so. Where should I set my rev limit to minimize stress on motor but to provide sufficient overrev for hill racing?
Old Nov 25, 2005 | 08:53 PM
choosetolose04's Avatar
I would say in the 7600-7800 rpm range. 8000 shouldnt hurt it. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 25, 2005 | 09:15 PM
DSNUT's Avatar
Thanks for the tip.
Old Nov 25, 2005 | 09:18 PM
[img]i/expressions/face-icon-small-wink.gif[/img] I actually rev mine out to over 8000 and Im stock, [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Nov 25, 2005 | 09:22 PM
DSNUT's Avatar
I ride on the Oregon Coast mostly so the racing I do is on Hills. These DS's have fairly wide ratio gears so I find myself dropping too low in the rpm range when I shift. It killed me when I had web109's. Obviously I need some overrev but I don't want to hurt my motor.
Old Nov 25, 2005 | 09:28 PM
Yeah, 8000-8200 really shouldnt hurt a thing with that build. I know those 12 paddles will kill you on the hill. They will get you out the hole pretty quick on the flats though, [img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 25, 2005 | 09:32 PM
DSNUT's Avatar
I have been running 10 paddle 22" extreme's but when we installed the 730 kit and the HPR Cams, the massive low end was causing me to blow out traction starting in second. It would blow out again when I shifted into third. I am going out tomorrow to try the 12 paddle to see if I can get some traction. Off subject on my own thread but any thoughts?
Old Nov 25, 2005 | 09:49 PM
Well, your running a pretty low gearing considering the hp & torque that your making. I would run the 12's first with the gearing that your running now and then change to the 10's with say a 16/40 and see what happens. I think you will be able to pull them...but its according to how big ah boy are ya, [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Nov 25, 2005 | 09:53 PM
DSNUT's Avatar
I weigh about 180. Thanks for the time. If I am not eccstatic with my 12's I will look at some gearing changes.
Old Nov 25, 2005 | 09:57 PM
Well, there is no doubt that more paddle is going to kill you on the top. Especially running the hill. I really think the 10's with a higher gearing will be the ticket. I run the 10 paddle extremes on the flats and I wouldnt have enough power to pull them up a hill. [img]i/expressions/face-icon-small-smile.gif[/img] Now, they get me out the hole but anything after 300ft and your not gaining anymore. Just a though. Hope this helped.
