LT80 Stalling
Old Nov 27, 2005 | 12:28 AM
chumbini's Avatar
Default LT80 Stalling
Help, I have a Jack Moore built lt80 motor that runs strong. However lately , it starts right up and runs fine until it is warm. Then it stalls if I don't keep revving it up. If it stalls it will restart if I use the choke. All suggestions accepted
Old Nov 27, 2005 | 01:49 AM
IdahoVinnie's Avatar
I would start by installing a new spark plug (even if it's not very old).
Old Nov 27, 2005 | 09:17 PM
Raptorflash1's Avatar
after you change the plug, check the float level, clean carb and line from gas tank. Check to see you get a good flow from your tank. After that CDI.
Old Nov 27, 2005 | 10:20 PM
hobbyracer's Avatar
ARE YOU SEEING A TEMP CHANGE. HERE IN IOWA WE HAD TO STEP UP THE JETS TO MAKE THE 50S RUN RIGHT
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
