Rear wheel horsepower
Old Oct 31, 2000 | 09:02 PM
matt400's Avatar
What would be the best way to increase the rwhp on a 400 scrambler? It doesn't matter how much hp you have if you can't get it to the ground.
Old Oct 31, 2000 | 11:26 PM
Phildogg's Avatar
I have a 99 scrambler 400 4x4 and I put an aaen pipe, and boysen reeds in it. Now it really rips!! I am putting 20x11x10 Razr's on douglas wide offset .190 Alum rims on the back and 21x7x10 Razr's on Douglas wide offset .190 Alum rims on the front. I am also getting it bored and stroked,works shox on it and an extended swingarm!!!
Phillip
Old Nov 1, 2000 | 04:02 PM
Zorro's Avatar
There's a difference between rwhp and power to the ground.
rwhp is directly linked to engine power, whereas power to the ground depends also on your suspensions, weight...everything.
Old Nov 1, 2000 | 04:46 PM
waynaferd's Avatar
MAN, I was just wondering this yesterday but didn't get to post it!!!! I was curious about that myself, since my stock Tblazer has 21hp, how much is getting to the dirt? I know the chain don't soak up the power like a shaft drive, but what about the pvt? Anyone ever dyno a quad for rear wheel power? How much is lost from the motor? Any help is appreciated....
Old Nov 1, 2000 | 09:17 PM
A400L's Avatar
For Polaris machines the key is to know how to clutch them. There is no specific kit you can buy to get X amount to the ground. It's all trial and error! Remember though that every additional mod you make that effects RPM's usually will require a slight adjustment. I would look into a roller clutch from HPD or AAEN.
Old Nov 1, 2000 | 11:00 PM
FearNothing's Avatar
I am not sure the exact amount, but on cars anyway, I think on an average they lose about 18% of the engines power due to internal friction and other things. Not sure if that is the right number and if it will help any of you, but...
Old Nov 2, 2000 | 06:18 PM
PolarisMan's Avatar
Keep the chain oiled. The easier the chain is to turn, the more power to the ground
Old Nov 6, 2000 | 09:53 PM
Jack's Avatar
Nothing affects getting hp to the rear wheels on a Polaris as much as clutching. But first you need to make hp to get it there since these systems are torque sensing. . Low hp / low torque machines do not respond well to clutching changes as well as those that have mega hp. You need to build the motor and then get the clutching to suite your own riding style.
Old Nov 6, 2000 | 11:45 PM
dano00's Avatar
Actually you should do your hp and clutching changes at the same time to get the best performance. Also Polaris states that the engines peak power is at 6800 rpm. even if you change hp & clutchs anything higher will result in damage!
Speaking from experience!!!!! Also you will need to make suspension changes as stated above. All the power in the world will do you no good if you can't get traction to make good use of the power
Old Nov 7, 2000 | 01:51 AM
Dazed's Avatar
I was told by a polaris rep that the pvt system has a 23% lose in power. from the engine hp.
