27" mudlite issues!!!
Old Nov 29, 2005 | 11:38 PM
DUBGRIZZ's Avatar
Default 27" mudlite issues!!!
I have a 2006 yamaha grizzly 660 and 14" itp c series wheels with 27 inch xtr mudlites. My issue is when i hammer the throttle the tires rub on the back of the floor board HELP!!!
Old Nov 30, 2005 | 01:15 AM
Daniel631's Avatar
Try adjusting the shock spring to the stiffest setting. Hoe much air pressure are you running in them???
Old Nov 30, 2005 | 05:24 PM
toepunch01's Avatar
Same problem either need to lift the quad, aftermarket shocks will help or trim the fenders
Old Nov 30, 2005 | 05:55 PM
OGGYDOGGY's Avatar
I had the same prob. on my Griz with 27" bear claws on if you look at my pics you will see where I cut mine they work good now and only hit if I really bottom out .I did stiffen up my shocks too. Check pic # 6 and also note the home made splash gaurd on the floor board I made it to keep the snow from comming up on me, a little cheaper than overfenders for know.
Old Nov 30, 2005 | 08:07 PM
DUBGRIZZ's Avatar
Yeah i am prolly going to lift the quad and trim the fenders also but if i only lift it will 2" be enough?
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
