750 BF air-fuel screws (05)
Old Dec 2, 2005 | 08:04 PM
kips750bf's Avatar
Default 750 BF air-fuel screws (05)
I'm a newbie to the site, so any help would be good. I'm looking for the air-fuel mixture screws on my 05 BF.
It seems to be running a bit rich. ( A little black smoke out the exhaust. )
Old Dec 2, 2005 | 08:52 PM
Daniel631's Avatar
They are underneath the carbs above the floatbowl on the engine side if the venturi. You will need an air/fuel mixture screw tool to get to them.
Old Dec 2, 2005 | 09:40 PM
kips750bf's Avatar
Thanks for the reply, the sticker under the seat says 2.5 turns out. Does this sound good? I'm hoping this will help
with the idle.
Old Dec 3, 2005 | 06:14 AM
Daniel631's Avatar
It takes a good ear and a little experience to get them just right. It's a little tougher with a twin. 2.5 turns would be a good starting point.
Old Dec 3, 2005 | 07:58 AM
kips750bf's Avatar
Thanks again I think I try to adjust them today.
Old Jan 2, 2006 | 12:50 AM
CSS4x4's Avatar
I am also new to the site and was reading through some of the older threads and was trying to find out more about the air fuel screws myself. When you say 2.5 turns out, do you mean 2.5 turns from all the way in or from where it is untouched from the factory. I need to richen things a bit. Should I turn them in a little. Any help would be appreciated.
Old Jan 2, 2006 | 03:40 AM
husky100's Avatar
The 2.5 turns out means from full closed. You would turn your screws all the way in until they are snug DONT OVERTIGHTEN, then back them out 2.5 turns. I normally watch the name of the screwdriver and count its revolution so I dont loose track. Hope this helps!!!
Old Jan 2, 2006 | 04:16 AM
Daniel631's Avatar
Husky is right on. But here is a little something you should know about carbs. Alot of people say "air/fuel" screw, but your carb has one or the other. Look at the carb profile(say the air box side is facing left and the engine side is facing right) and split it down the middle. If the mixture screw is on the engine side of the carb then it is a fuel screw. Turning it out will richen the mixture. If the mixture screw is on the air box side then it is an air screw. Turning it out will lean the mixture.
Old Jan 2, 2006 | 06:09 PM
CSS4x4's Avatar
The mixture screw is on the bottom of the carb right by the bowl and the airbox is on the top of the carb. Soo what your saying is that I am dealing with a fuel screw and that by turning it out that will richen the fuel mixture. I just want to be sure that I am doing this correctly before I start messing with things. Thank you both for your help.
Old Jan 3, 2006 | 12:42 AM
Daniel631's Avatar
Yes that is correct
