HELP!!!!
okay i was changing the back brake today on the blaster and we got everything back in and swaped out then i hit the foot lever and there was so sqeez on the pads what-so-ever. any ideas?? we have adjusted everything just trying to get it to work.....
Ok dude if its stock, you did it wrong. If its hydraulic, warryerrider was right, you gotta bleed em' and keep putting in fluid. On the inside of the caliper on the rear stock brake, you will find a set screw or a screw that you can turn in to push on the moving caliper side. I forgot if its on the outside or the inside but im almost positive you'll find it on the inside. Then turn that screw in until the brakes are snug. Then use the adjustment on the cable to make the brakes squeeze less. but definately look on the inside and make sure you puut everything back in right too, you should have to put some pressure when putting them in so if you didnt have to pull on the guts in the middle you probably did it wrong.
