Suggestions on LT80, just picked 2 up?
Old Dec 4, 2005 | 08:33 PM
TimH's Avatar
Default Suggestions on LT80, just picked 2 up?
Thanks everyone for leading me in the right direction getting new(er) quads for my boys. Now looking for suggestions on what to watch for, change and who knows what on 2003 Suzuki LT80. Everything seems good with them so far. Picked up yesterday and the twins even got lucky ehough to catch on first snow this morning with them.
Old Dec 4, 2005 | 08:56 PM
spike99's Avatar
If we had an LT80, I'd do the following to it:
1 - Install DRL (Daytime Running Lights) as seen in:
http://community.webshots.com/album/283371980xEWfck
http://www.rickystator.com/pages/LT8...ing%20kit.html
* For DRLs, dual front lights at 10 watts each would be better. To me, a double lights make better DRLs.
* For dark night riding (which I do NOT recommend to anyone under 16), then an upgrade High Output stator and double lights with 20W bulbs would work great. A single 35W light is ok but to me, it does NOT shine infront of the tires and sides of the trails very well.
2 - Install a mirror. This can be done by purchasing a universal mirror bracket mount and an inexpensive plastic mirror.
3 - Install a Chain Roller. For a picture, surf:
http://community.webshots.com/photo/...85036639IpsrAA
http://community.webshots.com/photo/...85036888TsJRNc
4 - Install Nerft Bars with heal protection. To me, a mini should come with full running boards or nerf bars. Foot peg design looks very dangerious to me.
5 - Widen the front end. This can be done by turning the front hubs around (and relocating the valve stem) or installing wheel spacers. 1.5 - 2.0 wider in the front dramatically reducing the risk of rull overs on sharp trail corners and/or doing donuts.
6 - Install Skid Plate / body armor. Being wider in the front, more things can catch its underside. Especially if bush / rock type trails. For picture surf: http://www.hebcodistributing.com/pages/youthpag.html
Hope this helps....
Old Dec 5, 2005 | 12:58 PM
TimH's Avatar
Thanks for the suggestions, never even thought of mirrors. They are a good idea. Also thinking about hooking up a brake light some how. So far the boys are having a blast on them. A big step up from a Kasea 50.
Old Dec 5, 2005 | 01:33 PM
spike99's Avatar
Picture of our mirror: http://community.webshots.com/photo/...48578044eQZUto
On our '03 Pred-90, I created / installed a foot brake with a working switch and converted its tail light to a combo Running Light / Brake Light. To do this, I peformed the following:
Upgrade Rear Tail light:
- Removed our factory Tail light. Took the light assembly to a few Auto Stores and found a much better assembly. An assembly that comes apart and was a much better design.
- Installed a much better mounting plate. re: Welded on a 90 degree bracke and its mounting plate is thin steel. Mounted the light assembly to be 2" further in.
- Removed its factory combo bulb and replaced with an LED Bulb. This gives better lighting and uses less 12V watts. Thus, more watts available from our front lights.
Pictures are:
http://community.webshots.com/photo/...48560967RRGsmT
http://community.webshots.com/photo/...48615124FKebkW
Foot Brake Switch:
- Created / installed Foot brake.
- Removed the foot brake switch from my 2001 AC 500i.
- Using my mini welder, I created a 90 degree mounting bracket.
Pictures are:
http://community.webshots.com/photo/...42859252KLTkJd
http://community.webshots.com/photo/...90216069eeexWK
Wired it all together:
For picture: http://community.webshots.com/photo/...93612273nAlTyF
Note: I used a Relay to allow our DRLs to only come on when our engine key is ON and its manual 12V switch is ON. For a quicker install, wire directly to your 12V battery. What ever design / install you are more comfortable with.
Hope this helps....
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
toonces
Oct 19, 2015 02:21 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
95wolv
Jul 17, 2015 08:13 PM
Wnthunting
Jul 9, 2015 03:02 PM
