Gear Postion blinking on 04 rubicon
Old Dec 8, 2005 | 09:21 PM
500rubicon's Avatar
Default Gear Postion blinking on 04 rubicon
today while back out off some water my gear postion indicator started blinking and the bike was acting like it was going to stall when ever i would give it gas in reverse.I goes away if i turn the key off and is fine i i restart but it starts blinking again if i put it in reverse esp and try to shift out of 3rd gear.Has anyone elsehad this problem or know what could be wrong?
Old Dec 8, 2005 | 11:07 PM
RideRedOrStayHome's Avatar
it sounds like a sensor or the hondamatic unit wich is $$$$$$$$$$
Old Dec 9, 2005 | 07:13 AM
dzzy's Avatar
Count and post the number of blinks...it's a diagnostic code. How deep was the water? Maybe a connector got wet.
Old Dec 10, 2005 | 10:53 AM
500rubicon's Avatar
It just keeps on blinking i started to count but it went past 20 so i stoped.the water was to the top of the tires and when i started to back out as soon as it hit the bottom of the lights it started to blink
Old Dec 15, 2005 | 10:09 AM
BIGBADBOB's Avatar
Try this.
Rubicon Hondamatic Code Retrieval
1. Put the gear shift lever in neutral (be sure the neutral indicator comes on) and the ignition switch OFF (vehicle at a stop).
2. While pushing the UP and DOWN shift switches (ESP) simultaneously, turn the ignition key to the on position.
3. Release the UP and DOWN switches immediately, then at the same time push both the UP and DOWN shift switches again and hold form more than 2 seconds.
4. The problem code is displayed by a certain number of blinks “ - - “ on the gear indicator, which indicates the problem code by the number of blinks. If “N” (neutral) stays ON on the position indicator, the retrieval process was not correctly performed. Repeat the procedures from step one at this time.)
5. When the problem code(s) displays, release the shift switches.
You should see “ - - “ for approximately 3 seconds then off, then the “ - - “ should flash, once for code one, twice for code two and so on. The engine control module (ECM) can store two different codes. If your ECM has stored two different codes, the first code displayed is the most recent and the second code is the earlier code. Write them down.
To Erase the Problem Codes
1. Push and hold the UP and DOWN shift switches simultaneously for 3 seconds of more while the problem code is being displayed (i.e., “ - - “ blinking on the gear position indictor).
2. When the erasure is completed, the blinking pattern changes to the erasure confirmation blink.
3. Turn the ignition off.
Initial Setting Procedure
Note:
· After replacement of any of the following parts, perform the initial setting procedure below.
- ECM
- Throttle sensor*
- Angle sensor
*Also, perform the initial setting procedure if the throttle cable is disconnected (i.e., car-buretor removal/installation, cable replacement etc.).
· The gear position blinks in Indicator Mode 2 when the initial setting was not made properly. Repeat the procedure from step 2.
1. Start the engine and let it idle about one minute with the sub-transmission in neutral. Stop the engine.
2. Make sure the gearshift lever is in the neutral position (be sure the neutral indicator comes on) and turn the ignition switch off.
3. Turn the ignition switch ON while pushing the UP and DOWN shift switches (ESP shift switches) simultaneously.
4. Release both the UP and DOWN shift switches immediately, then push and release the shift switches in the order of UP, DOWN, and UP. Do not hold the switches in).
5. A constant “ - - “ indication stays ON on the gear selector indicator. (If the gear position indicator shows a continuous “N”, repeat the procedure from step 2.)
6. Move the throttle lever to the fully closed position, then to the fully open position, and then move it to the fully closed position again immediately (within 10 seconds) after “ - - “ comes ON on the gear position indicator.
7. Check the control motor operation sound (the control motor should function at this time to adjust the angle sensor).
8. When the initial setting procedure is complete, the indication on the gear selector indicator changes from the continuous lighting of “ - - “ to the continuous lighting of “N”.
Code 1 - Ignition Pulse Generator system
Code 2 - Speed Sensor System
Code 3 - Gear Position Switch System
Code 4 - Throttle Sensor System
Code 5 - Angle Sensor System (Motor lock i.e., angle sensor, wiring, ECM, control
motor, motor transmission section, transmission unit)
Code 6 - Angle Sensor System (swash plate angle, sensor / wiring)
Code 7 - ESP shift switch system
Code 8 - ECM EEPROM
Code 9 - ECM voltage converter circuit
Code 10 - ECM fail-safe relay circuit
Code 11 - ECM motor drive circuit
Code 12 - ECM CPU
Old Dec 15, 2005 | 06:02 PM
CdnRedneck's Avatar
Do all Honda ESP shifters have the same codes for problems.
Old Dec 15, 2005 | 08:24 PM
BIGBADBOB's Avatar
I don't know if they do, I got this info from another forum. I have had my Ruby for 6 days and ridden it a total of 50 feet!!! Will be going out this Saturday for my first ride on a ATV ever!!! In the snow no less!!!
Bob
Old Dec 15, 2005 | 08:36 PM
dzzy's Avatar
No they don't all have the same codes...you could also search this forum for more info. I know Specta has posted that same info at least a few times.
Old Jan 13, 2006 | 02:00 PM
moises03rubicon's Avatar
I'm having pretty much the same problem. I was riding one of my usual trails, and when I was coming out of the trail through some mud I got stuck and tried to reverse out and it sounded like it wanted to stall out. So one of my friends w/ a 04 Rubicon pulled me out onto the road I tried reversing and it was still doing the same thing. When I tried going forward it runs fine, no stalling at all, except it won't come out of first gear. I did the diagnostics thing and got five blinks out of it. Are there any suggestions on what the problem is?
Old Jan 16, 2008 | 10:06 PM
Blake3612's Avatar
seems I have the same problem. did you figure it out??
