P360 Improvments
Old Dec 16, 2005 | 08:04 PM
strings's Avatar
Default P360 Improvments
I have a 2004 360 Prairie and it's a great machine. It's gotten me thrue everthing that I've had to make it thrue. But it isn't very exceiting. So my question is what are some of the best ways to get better throttle responce out of it?
Strings
2004 Kawasaki 360 Prairie
Full Skidplates
Moose Hand Guards
Old Dec 17, 2005 | 01:57 AM
alwaysride's Avatar
Id say get some clutch springs. I have the epi black and it helped some.
Old Dec 17, 2005 | 08:25 AM
jamakn's Avatar
I was thinking about adding a pipe in the spring and changing out my stock air filter, would that give me a lil' pep?
also, debating adding spacers, kinda feels high at times....
Old Dec 18, 2005 | 12:07 PM
strings's Avatar
Would A Primary and secondary be better than just a secondary? Also How much does the black EPI Spring Cost.
Strings
Old Dec 18, 2005 | 12:12 PM
strings's Avatar
Jamakn in your picture gallery you have hope floats. Did you have water get in anywhere.
Strings
Old Dec 18, 2005 | 01:45 PM
alwaysride's Avatar
Clutch springs are the cheapest mod. I would def get the black secondary and pick a good primary. My primary is still stock but i might just get the 700 stock primary. I heard that helps take off.
Old Dec 18, 2005 | 10:27 PM
Camoprairie's Avatar
With the Mods I've made it has definately made a difference. Throttle response is much better. I weigh 220 and I can get the front tires off the ground on with my butt on it. A lot better than stock - low and mid-range way better, top end still sucks. Looking into a HP Cam and higher comp piston. I should have just bought a stinkin 650!
Old Dec 20, 2005 | 12:41 PM
jamakn's Avatar
Strings...
yeah water everywhere....actually sunk the bike, got off, it popped up and floated on fenders to where you can see it sitting on mud again and me getting winch cable out...
sucked!
that was the end of my day...
I got so deep and it must have flooded quiuckly (deeply) and she shut down...
got out of hole and friend started trying to kick it over b4 we could stand it up and drain water out of exhaust....
made for long evening, since we were in Canada on riding excursion....changed oil several times and ether in carb...
tons of water in exhaust and crank case too..
she takes a lickin and kieeps on tickin...LOL
got home, flushed oil again, another new filter & plug and been riding her since...will probably have valves looked at during next dealer service...just to be on the safe side...
Old Dec 20, 2005 | 05:36 PM
alwaysride's Avatar
Hey jamakn,
how is your venom winch holding up. My buddy is thinking of getting one for his outlander and I wanted to know how yours is. THanks.
Old Dec 20, 2005 | 07:53 PM
jamakn's Avatar
holding up well...been using it for plowing. had two stroms and used it for total of almost 2 hours....holding up well!
it also was used several times pullling the machine.
It's the 2k flavor, I think its worth the $100.00
Bratman2
Aug 6, 2022 01:42 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
antiguogrumete
Sep 5, 2015 03:41 AM
4464
Aug 21, 2015 01:46 AM
bpegram84
Jul 22, 2015 08:15 AM
