red cat 110 air filter
Old Dec 17, 2005 | 12:59 PM
red123's Avatar
Default red cat 110 air filter
I have a vx110 red cat it came with a kn air filter right on the carb but i would like to get the parts to run it to the air box on the front of the machine called the dealer they said they could not get the parts to try a yamoto dealer any idea were to find the right parts?
Old Dec 17, 2005 | 02:42 PM
2manytoys's Avatar
red123,
You will want to keep the K&N on it. The stock airbox and filter are not very good. They let alot of dirt past because they are not sealed good. If you can figure out a way to mount the K&N up high or under the nose cone that would be ideal. You can go directly to the kazuma/ redcat site and look under the parts list.
Old Dec 17, 2005 | 07:26 PM
chubbysdad's Avatar
Goto Homedepot and get some pvc tube and a rubber connector and run it into the front air box and keep the k&n in there.
Old Dec 19, 2005 | 09:04 AM
red123's Avatar
I thought about that but the kn air filter dont fit
Old Dec 19, 2005 | 10:37 AM
chubbysdad's Avatar
It seems to fit fine. There is plenty of room in that front box. Just put an elbow on it if you have to.
Old Dec 19, 2005 | 05:17 PM
red123's Avatar
your right it will fit if i put an elbow on it if i go with 1inch hose to fit over the carb inlet will i run into an air flow problem
Old Dec 19, 2005 | 07:52 PM
2manytoys's Avatar
red123
If you dont ride in any deep water the air filter will bolt right up to the carb. The airbx is not sealed very well anyways and is not waterproof so you may want to just bolt it right to the carb anyways. The carb has a 1.5 inch flange. You wont run into an airflow problem because the K&N allows alot more air than stock anyway.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
