KFX400 Suspension Adjustment
Old Dec 18, 2005 | 01:13 PM
drnez's Avatar
Default KFX400 Suspension Adjustment
I have an 05 KFX400 and need some information regarding rear suspension adjustment. I'm a small guy (around 140lbs) and would like to know what I can do to soften the rear suspension. My friends ride Z400 and have no problem pulling up the front end in 1st, 2nd, 3rd, and even 4th gear. I struggle to get mine up in even 2nd and 3rd, I really have to jump down on the back of the quad to get it to pull up. Seems like my weight may be an issue as there isnt enough weight on the back to pull it up easily. How can I go about adjusting the suspension in the rear to compensate for my light weight. Thanks in advance!
-Frank
05 KFX400 (stock)
Old Dec 18, 2005 | 01:16 PM
05KFXKingQuad's Avatar
Take a straight head screwdriver and adjust the screw towards the S, but only a 1/2 turn at a time and try that out...
Old Dec 18, 2005 | 01:17 PM
drnez's Avatar
wow, fast reply! I'm going out to take a look at it right now. Thanks!
-Frank
05 KFX400 (stock)
Old Dec 18, 2005 | 01:24 PM
drnez's Avatar
Its just the small screw in the middle, not the entire ring, correct? I turned it about a half a turn, gunna go out and test ride it, Not really sure if I'll be able to tell the difference as we have quite a bit of snow here, still got some kold kutters in there, but ill give it a whirl. Thanks!
Old Dec 18, 2005 | 01:27 PM
YES, just the little screw. I think it is a goldish color. For your weight you might want to turn it another 1 1/2 turns...
Old Dec 18, 2005 | 03:19 PM
yellowrider250ex's Avatar
[. I struggle to get mine up in even 2nd and 3rd, I really have to jump down on the back of the quad to get it to pull up. Seems like my weight may be an issue as there isnt enough weight on the back to pull it up easily.
-Frank
05 KFX400 (stock)[/quote]
I can't keep mine down
Old Dec 18, 2005 | 05:18 PM
honda400rider's Avatar
I got the 06 and I can catwalk it in any gear. Just gotta get the revs up a bit in 4 and 5. All stock. And I don't need to pull up that much.
Old Dec 18, 2005 | 05:43 PM
drnez's Avatar
seems to be the problem is traction, my kold kutters are warn from street riding. I rode my buddies DVX400 with fresh screws, had no problem pulling it up. Thanks for all the help.
-Frank
Beeline08
Nov 11, 2016 04:00 PM
Robinhood
Dec 26, 2015 10:28 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
