predator lowering kit??????????????
Old Dec 18, 2005 | 08:49 PM
upssmann's Avatar
Default predator lowering kit??????????????
Dose any one make a lowering kit for the predator?? if so where do I go to find these lowering liks and went to e-bay and found nothing ???? HELP...............................
Old Dec 18, 2005 | 09:17 PM
spyder6's Avatar
www.hpd-inc.com
under predator accesories
Old Dec 18, 2005 | 10:17 PM
2mnyToyz's Avatar
see how you are!
Buy a couple Rappy shocks on e-barn for the front... Completely unload the rear shock and you'll be set.
You'll have to grind the lower shock bushing a little in order for it to fit on the a-arm mount, top is fine. I'd recommend a Rath sway-bar. Check-out my pix for that set-up. I have two preddys set-up that way and it works really well... YFZ shocks work too, but the rezzies make them more spendy.
Old Dec 18, 2005 | 11:54 PM
spyder6's Avatar
why trade out nice Fox shocks for sh1tty raptor shocks? HPD makes a spring kit, and its a tripple rate so its gonna make the ride even nicer.
Old Dec 21, 2005 | 03:50 PM
2mnyToyz's Avatar
see how you are!
The set-up works for me, bolts right on. Doesn't take that long to swap from sand to flat track. Just listing an economical way to lower the quad. Don't need much of a shock for flat trackin'.
Old Dec 21, 2005 | 04:47 PM
GITRDUN's Avatar
CRJ has lowering kits for the predator http://www.crjperformance.com/loweringkits.html . Have them on my wifes predator.
Old Dec 21, 2005 | 09:23 PM
cr125predator's Avatar
CFM makes them too. I have them and i would not reccomend getting the CFM unless you work in a machine shop, where you can mill them down. Thats what we had to do.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
