Help please!!!!!!!
Old Dec 21, 2005 | 04:58 PM
NHarrison2's Avatar
Default Help please!!!!!!!
I have a 05 prairie 360. The belt light is staying on. It still runs great though. What does this mean and how can I fix it? Thank you all for your help.
Noble
Old Dec 21, 2005 | 05:55 PM
alwaysride's Avatar
At 100 hrs or around there you light will come on. Just check your belt and see if it has any visible problems and then reset the belt light. Its simple.Procedure:
under the shifterthere is some connectors. Fine the two big ones(5 pin) that are BLACK AND GREY. Take them apart and switch the colers so it will be black to grey and vise versa. ( there is also one connector that wont fit, if you accidently try to put that together it wont fit so you know its the other two). Next there is a 2 pin connector that is small and black. Dissconect this. Next turn your key on for 10 secs and wath the light flash. Then turn it back off and put everything back to normal. The light should reset. Good luck and if all this rambling doesnt help ill put it to ya in a better for[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 22, 2005 | 08:35 PM
NHarrison2's Avatar
Thanks for your help. I'll try it this weekend.
Noble
Old Dec 24, 2005 | 09:57 AM
NHarrison2's Avatar
I don't want to sound stupid but I'm not sure what your talking about in regards to 5 pins?? Does anyone know of any pics that show what it looks like? Has anyone experienced their 360 to be very cold natured? It will die at every stop for the about 10 minutes.
Noble
Old Dec 24, 2005 | 12:06 PM
thescout's Avatar
yes they are cold natured , but the valves need setting to proper clearance,,,this makes a huge difference in it going dead ect.....nyroc has the proper procedure,,message him about it
Old Dec 24, 2005 | 01:44 PM
NHarrison2's Avatar
I did the switch on the plugs and it worked!! Thanks a million. I will go to the other site about the valves. Thanks for all the help.
Noble
Old Dec 24, 2005 | 05:59 PM
alwaysride's Avatar
good, now remember that procedure incase you need it on the trail because it can happen. peace
Old Dec 24, 2005 | 06:07 PM
thescout's Avatar
try here: http://atv.dnsalias.com/forum.cgi?vi...0&viewtopic=84
there was a very detailed posting of this . but i cannot seem to re locate it
Old Dec 24, 2005 | 11:36 PM
husky100's Avatar
Good Advice. There are some other post on here just for the belt re-set light issue that may help you a little further.
