bayou 220 need help
Old Dec 26, 2005 | 08:56 PM
therigwelder's Avatar
Default bayou 220 need help
this is my first atv,i picked it up for 200 bucks and it has some problems .the biggest problem is i have no fire.the electic start dosent work so i figure to get it to run with the recoil then figure out the electric start.i have 12v going into the coil under the seat one wire is green with a white tracer the second wire is a black with yellow tracer both have 12v.i am a little confused how the ign. system works. the engine has excellent compression and gas to the carb.can someone explain to me how to get fire?i pulled the plug and grounded it so i am sure there is no fire when cranking
Old Dec 28, 2005 | 12:51 AM
ok, maybe ive got the wrong forum[img]i/expressions/face-icon-small-happy.gif[/img] or maybe nobody has a clue
Old Dec 28, 2005 | 01:52 AM
IdahoVinnie's Avatar
The coil has 2 small wires. 1 of the wires is "hot" when the ignition is turned on. The other wire goes to a triggering device (as points do in an older auto) that makes and breaks contact to ground with the rotation of the engine. This is what creates the spark.
Use a test light and touch it to each of those 2 wires at the coil. With the ingition "on", rotate the engine. One of the wires should stay "on" constantly. The other wire should cause the test light to blink. If it doesn't blink, then there is something wrong with the triggering device.
Let us know what you find!
Old Dec 28, 2005 | 12:21 PM
terry25's Avatar
ok got the same problem,constant power two both sides of the coil? I've ohm;d checked the trigger ok.why is ther power to both sides? Thanks
Old Dec 28, 2005 | 12:37 PM
hondabuster's Avatar
Are the wires to the coil disconnected at the coil when you do the voltage check?
What year is the bayou?
Old Dec 28, 2005 | 01:20 PM
terry25's Avatar
nope wires connected and I'm not sure about year my son just picked it up i'm guessing late 80's early 90's model KLF 300A or KLE 300A
power to both sides,doesnt flash either side when cranking
Old Dec 28, 2005 | 01:55 PM
If the wires are still connected, then you will see voltage on both sides of the coil, youre just seeing the voltage come thru the coil,which is normal.
I dont have a service manual for that quad, but maybe someone else does, Theres a troubleshooting guide for figureing out the problem, in the manuals,
If no one else helps out, check ebay for a used manual, or try the local library for a copy. Itll be in the 629.2 area of non fiction.
Old Dec 28, 2005 | 03:29 PM
terry25's Avatar
Thanks Terry
Old Dec 28, 2005 | 09:09 PM
ive got a 97 bayou. I checked the voltage with the wires off ,constant power to both wires. the trigger device you all refer too, is it housed in the coil or is it the black box on the front of the frame below the hood?
If i am trying to start it with the recoil(to see if i can get the bike to run)wouldnt i get fire from a magneto to the coil and basically bypass the electronics?
Old Dec 29, 2005 | 12:50 AM
Daniel631's Avatar
If you have constant power to the ignition coil with the key on bike not running, then you have a DC CDI ignition system. There is one wire going to the coil from the battery, the other goes from the coil to the CDI box. There is an SCR inside the CDI box that must recieve a small voltage signal from the pulsor coil in order to shunt the battery to coil circuit. The collapsing magnetic field inside the ignition coil is what provides the spark.
Check the pulse coil for A/C voltage.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
