loud popping
Old Dec 27, 2005 | 04:06 PM
polarisman69's Avatar
Default loud popping
i just installed the fmf megamax on my 99'sportsman 500.i figured i'd have to rejet, but i just want to make sure im doing everything right. decided to run it with no discs, for more airflow. but when i get off of the gas it pops on deceleration. this is due to a lean engine correct?so is there an air/fuel screw i can tinker with to richin it up? im trying to avoid going out and buying a jet kit since moneys running low, but ultemently i think im going to have to. thanks alot
Old Dec 27, 2005 | 09:33 PM
scrammersam's Avatar
that sounds to me like its just back firing
Old Dec 27, 2005 | 10:08 PM
IdahoVinnie's Avatar
If it BACKFIRES through the carb on accelleration, it is usually too lean.
If it AFTERFIRES through the exhaust on de-acceleration, it's usually too rich.
Usually if you install a less restrictive exhaust system, the air flow is increased, thereby requiring a richer mixture.
The air/fuel screw should only have an effect on the idle circuit (and slightly above).
If it's a mild poping, this may be acceptable. A check of the spark plug would give you a better idea of it's running condition.
Old Dec 27, 2005 | 10:36 PM
yeah i think i'll check the plug tommorow, i dont think its backfireing, since it pops about 10 times coming off the throttle, but im not sure
Old Dec 28, 2005 | 11:13 AM
thewild1's Avatar
Put the discs back in the muffler they are there for a reason .Takin the discs out can harm your engine and prolly give you less performance than with them in.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
