can I increase the range of the LT80 variator
Old Dec 27, 2005 | 05:27 PM
crowfly's Avatar
Default can I increase the range of the LT80 variator
This is a multi-part question, so I'll try to keep it as simple as I can.
Do the front & rear sections of the variator run out of travel at the same time?
If you attempt to increase the travel, will the belt begin to rise out of the front section or will the belt bottom out in the rear section?
Can the Front & or rear sections be modified for increased travel. If so, how is this done?
I know that I can change sprockets & gear higher or lower, but I would like more range out of the variator. Thank You Very Much, crowfly
Old Dec 28, 2005 | 04:47 AM
Fastestdad's Avatar
I believe they dont have both clutches that change the range like on other minis. Heres a bump maybe LT 80 or someone else will reply.
Old Dec 29, 2005 | 12:50 PM
crowfly's Avatar
Thanks for your reply .
Old Dec 29, 2005 | 01:13 PM
LT80's Avatar
LT80 Expert
You can "adjust" the rear clutch travel for more speed.
The answer for the front clutch is NO. [img]i/expressions/face-icon-small-smile.gif[/img]
The stock clutch set-up does a great job for stock motors.
Gear up.
ReconBayou
Oct 31, 2022 05:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
2many2ride
Sep 27, 2015 04:35 AM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
