05 500 HO belt Problems
Old Dec 28, 2005 | 06:28 PM
8675309's Avatar
Default 05 500 HO belt Problems
I have a 2005 Sportsman 500 and at about 600 miles I blew the drive belt, it was covered on warranty and they supposedly checked alignment and cleaned the clutches. When I got it back I took it out for a ride and tried to climb a ditch that I had climbed lots before(I did use Hi gear, but so did all of the guys I was riding with) and the belt just smoked and I did not even move, ever since that time I felt vibration from the clutch and loss of power and topend. I took the cover off the clutches to inspect the belt and noticed that one spot on the belt sat lower in the secondary clutch(Probably from getting smoked). So I got a new belt and cleaned up everthing and it ran great, lots of power and I got my topend back. But now I can smell buring belt all the time, even driving down the road I smell the belt slightly, and I am starting to notice a decrease in power and topend again.(belt only has about 100 miles on it). What could be wrong? Clutches misaligned?
Thank's
Old Dec 28, 2005 | 10:45 PM
IdahoVinnie's Avatar
I would wonder if it has the proper belt deflection. (The distance between the 2 clutches may be too close/far apart.) (Alignment is having the 2 clutches paralell to each other.)
Old Dec 29, 2005 | 03:03 AM
jimmypsp700's Avatar
The belt should be taunt, no deflection on an EBS machine.
You have a flat spot on your belt and should be using low on inclines at slow speeds or from a stop.
Jim
Old Dec 29, 2005 | 03:45 AM
Polaris500HO4x4's Avatar
If you are going from a stop in High Gear up an incline hit the throttle quicker for a faster grab on the belt, when it engages slower the belt has more time to slip
Try running the quad with the belt cover off and see how the belt looks when idleing, it shold be free the the clutch on both sides, revv the engine a bit and see how the clutches act
Old Dec 29, 2005 | 10:26 AM
8675309's Avatar
Is it normal for the belt to sit above the secondary clutch about an 1/8" of an inch all the way around or should it fit flush?
Old Dec 29, 2005 | 10:30 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
most sit 1/8 inch above on the secondary clucth
Old Dec 30, 2005 | 10:50 AM
8675309's Avatar
When I put it in "N" and rev it up it hesitates between 3500-4000 RPM for half of a second then it revs up to where it should. It seems that when I am driving it won't rev up and this is why I am burnig belts? Why would this be? Is the secondary clutch not opening properly?
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
trouttracker
Jul 20, 2015 11:54 AM
