cleaning oem air filters
Old Dec 31, 2005 | 10:37 PM
weimy's Avatar
Default cleaning oem air filters
What is the best way to clean the oem air filters? I have a 2000 trx300fw and it is a foam filter. Or should I just buy a new one?
Old Dec 31, 2005 | 10:45 PM
yellowrider250ex's Avatar
I would reccommend you buy a K&N filter with a recharge kit, but if you want to keep a foam filter get a UNI
Old Dec 31, 2005 | 10:51 PM
weimy's Avatar
I was thinking about a K&N but is there any way to clean foam filters?
Old Jan 1, 2006 | 12:07 AM
Porka's Avatar
The best way is to buy the two bottles at the Honda dealer. Cleaner, and filter oil. Follow instructions on the bottles. If you change to a K&N your jetting should be changed or you will run lean, bad for the engine.
Old Jan 1, 2006 | 02:01 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
K&N's are for the street. Avoid them like the plague for off-road.
It's pretty simple. I spray the dirty filter with PJ1 Foam Filter Cleaner. Let it sit 15 minutes, then rinse FROM THE INSIDE OUT with warm water. Squeze it out (but don't wring it), and let it air dry. Don't forget to reoil it. My preference for oil is Maxima FFT.
You can use just plain old dish soap as well, but it doesn't work as good.
Old Jan 1, 2006 | 01:05 PM
hondabuster's Avatar
Its not a big deal to clean the filters, heres a couple of links to articles on how to.
dirt wheels
atv connection
And i agree, if the quad is going offroad, stick with the foam filters.
Old Jan 1, 2006 | 01:18 PM
Red Rider
I know the Honda owners manual says to dip it in a solvent, like Kerosene. The reason I don't like this is that it tends to remove the oil, but leave the dirt behind. The reason I like flushing it with water (from the inside out), is that the water carries the dirt out with it.
Actually, the PJ1 has a solvent and detergent together, best of both worlds.
COFatboy
May 2, 2020 12:06 AM
cody500ho
14
Aug 14, 2015 05:03 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
