Loose with $120 bucks....yea....
Old Jan 1, 2006 | 11:58 PM
fasterthanyou22's Avatar
Default Loose with $120 bucks....yea....
Hey, what good power performances parts could i get for 120 bucks or less.If i got an intake kit it would need to have the jets included.
Old Jan 2, 2006 | 12:50 AM
CTracingraptor's Avatar
you cant touch anything on that bike for under $150. As far as power, i would get ride of your white bros and try again with a different pipe, sell the one you got(ebay) save up and getter a better pipe. also is your airbox off.....
Old Jan 2, 2006 | 01:22 AM
Nope, still got the airbox.I only have a drop in filter though.I could get a pro design or gytr for like....116 or 120.With no jets......But yea...I am going to try and get an exhaust for it.Im thinking hmf, not too pricey, great power gains so I have heard, and comes with jets.But if i take that path i will have to handle the hills and holes when that time comes, because i know there will be frustration installing it.There always is when i am doing something to that bike, or any bike for that matter.
Old Jan 2, 2006 | 06:13 AM
slidesquad's Avatar
stage 1 hotcams 130$ plus shipping on ebay
Old Jan 2, 2006 | 06:38 AM
choosetolose04's Avatar
Well, you could buy you a couple of sprockets to put the power where you want it...either down low or up high...they are relatively cheap. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 2, 2006 | 07:49 AM
Ozark38's Avatar
Get the Pro-Flow K&N and lose the lid. I would also recommend what CT said and get a different pipe. I had really good gains with the HMF full system on the 660.
Old Jan 2, 2006 | 03:08 PM
take your air box lid off and re-jet first, you'll gain easy power by taking it off. the look into buying another pipe. i wouldnt worry about changing cams just yet, look at getting the best pipe for the money you can. then i would highly recommend porting the head(if anything do it yourself and just smooth it out)
Old Jan 4, 2006 | 03:43 AM
maddog56's Avatar
Stock bore piston, 125 bucks if you can install and hone yourself.
If you've already got a K&N, pipe and had it rejetted why would an intake even be a consideration? Did you just buy an oem like drop in K&N and not something like the prodesign or gytr kit?
Old Jan 4, 2006 | 05:44 AM
Starky's Avatar
The Whitebrothers R4 was one of the best pipes made for the 01 Raptor, keep it.
Get a pro Design flange and filter and lose the air box lid. You'll have to re-jet but you won't believe the feeling.
You could also get the "Power Now" carb inserts. I don't have first hand experience with them but they are supposed to improve the air flow and increase the power.
Old Jan 4, 2006 | 05:50 AM
Starky's Avatar
CT, you need a pink fur bar pad on that machine.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
jankerstien
Sep 21, 2015 03:09 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
