grinding noise from back clutch area
Old Jan 2, 2006 | 03:18 PM
littlecanuck74's Avatar
Default grinding noise from back clutch area
05 700 praire i have a grinding sound coming from the back clutch area only present when driving and cant seem to figure it out.the dealer thought it was 4x4 accuator so they replaced it but it wasnt the fix then they thought it was the bearing on the front clutch so changed it still no fix.the bike is working good as usual just making this annoying noise no belt wear or anything out of the ordinary.any suggestion would be greatly appreciated thank you in advance
Old Jan 2, 2006 | 09:22 PM
handycap's Avatar
The inside of rear clutch may be dry or very dirty with belt residue. Center out rear clutch has some grease in it to lube the expansion and compression action of shives.
Or the shim on back side of rear clutch may be gone and clutch is touching the inner housing.
You could take cover off, run engine and check noise, then remove belt and run engine again and listen for noise. Sound travels...............
Good Luck, couple more things to check.
If still under warranty let dealer fix it.
..............handycap.................
Old Jan 3, 2006 | 10:13 AM
thanks for advice will check it out for greasae and yes there is still warranty on it but the dealer cant figure it out either+ +first they thought it was the actuator then they thought the bearing which were both replaced one there cost and one mine
MikeyBoyesq
Nov 27, 2020 02:44 PM
Rocketx
Nov 16, 2020 07:25 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
old quads
Aug 13, 2015 10:32 AM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
