question on the corrosion issue with older cannondales
Old Jan 4, 2006 | 12:50 AM
Exrider22's Avatar
Default question on the corrosion issue with older cannondales
I understand that the older cannondales had the same problem and thought you guys could help........i brought in my kfx400 to the dealership and of course it had begun to corrode. Under the warranty theyre going to replace everything fan cover etc. etc. Right now thouigh the dipsh*ts at kawasaki ordered me a new cover but its the same magnesium one. I explained that i NEED a aluminum one though. Im in the process of arguing with them and want to know if i should just use the same magnesium cover but with evans coolant or if i should order the aluminum one? thanks!
Old Jan 4, 2006 | 12:55 AM
smitty911's Avatar
Save your fustration and get your quad back. Flush the system and than use the Evans. Do they even have an Alum one to order?
You could always Powder coat the area and than run Evans.
Smitty
Old Jan 4, 2006 | 12:58 AM
Exrider22's Avatar
well i got the warranty so there going to replace everything thats corroded for free. I can order the aluminum one but you thing i should spend the money on it or just run evans?
Old Jan 5, 2006 | 12:06 AM
WISTECH's Avatar
If they wont buy you a aluminum cover just run the evans. You will never have a problem or have to mess with the cooling system again.
Old Jan 5, 2006 | 01:42 AM
Exrider22's Avatar
great thats what i wanted to hear. they wont replace it with the aluminum one so im picking up some evans. i need to get type npgr correct?
Old Jan 5, 2006 | 01:45 AM
WISTECH's Avatar
npg+r is the lifetime stuff.
Old Jan 5, 2006 | 01:47 AM
Exrider22's Avatar
thats what the people at evans reccomended, think i should use that or is there something better?
Old Jan 6, 2006 | 10:32 PM
smitty911's Avatar
Thats the stuff. Get it and forget the worry.
Smitty
Old Jan 7, 2006 | 01:03 PM
Exrider22's Avatar
cool thanks appreciate the help
1966F100
Jul 12, 2015 03:08 AM
Unzzy66
Jul 11, 2015 10:01 PM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
ranvette
Jul 4, 2015 06:13 PM
