01 raptor & 05 YFZ 450, oil change info and spec needed.
Hi, could you go over the oil change/check procedure fora 01 raptor and a 05 YFZ 450, I need oil amounts torque specs, and all the info you have thanks.
go to www.sandwizards.com and download the service manual for both bikes, then follow the procedures.
Ok, I checked all over thqat site and I could not find anything,
I need to know 04/05 YZF 450 the,
1 amount of oil it takes,
2what type of oil it takes
3torque specs for both oil drain bolts
4correct way to check oil.
01 raptor
thansk a lot
01 raptor
thansk a lot
good site. yep, service manuals are on there. i just went thru the YFZ one. Pretty interesting that they say change the oil every 1 month, then at 6 month intervals. I would think the intervals would be more frequent than that, considering the kinda revs the engine makes and a yamaha rep said to change it every 5 rides...
how often do most of you YFZ owners change it?
HINT: when you go the main sandwizard page- look on the left side of the screen at the list. pick "tips and tricks". when that page loads, then click the big blue letters that spell out "SERVICE MANUALS." Dont click on the individual bikes b/c there is nothing there (well under the raptor they have how to disconnect the reverse limitor or something). after that comes up, scroll down and you will see the yamaha bikes listed and the manual is in PDF format for you to look at or download.
found them, I went to my favorites and clicked on the wrong link, i was at flat out racing . Thanks
this is for the raptor. the total amount of oil is 2.43 quarts and that is the oil filter and everything
oil filter torque in 12 ft lbs.
crankcase bolt torque is 22 ft lbs.
oil tank bolt torque is 18 ft lbs. after your done changing it start the quad and rev it several times and shut it off and check the oil. is that everything or do you need more info.
