Redcat 50cc Rear Axle
Old Jan 7, 2006 | 09:44 AM
carolina4wheeler's Avatar
Default Redcat 50cc Rear Axle
While working on the atv, I found that the rear axle is difficult to turn with the chain removed. Also, there is a squeak while turning. I loosened the locking nuts on the right side of the axle shaft, next to the brake drum seal, and was able to free up the axle a little. It turns very easily with the nuts backed out completely, however if I adjust them to eliminate side play, it is again hard to turn. Does anyone know the correct procedure to setup the rear axle?
Old Jan 7, 2006 | 11:08 AM
2manytoys's Avatar
Are you sure it is not the brake slowing it down. It may be that you loostened the nuts and it is puting more slack in the brake cable but when you tighten them back up it tightens the cable. Loosen the brake cable all the way and see what happens.
STLyamwar
Jul 25, 2020 04:44 AM
snowolson
Aug 31, 2015 03:51 PM
Dammar
Aug 26, 2015 07:12 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
