2000 Blaster Hard To Start
Old Jan 8, 2006 | 06:15 PM
Kylek911's Avatar
Default 2000 Blaster Hard To Start
My Blaster is hard to start. It will start up affter a while but will not start right away. Does anyone have any ideas?
Old Jan 8, 2006 | 07:52 PM
Boombotz's Avatar
1.how long has it been since u started it
2. using ur choke?
3. carb problems in past?
Old Jan 8, 2006 | 08:38 PM
Kylek911's Avatar
I started it 2 days ago it runs when it starts its just hard to get started. Yes Im using the choke there has not been any carb problems in the past
Old Jan 8, 2006 | 09:19 PM
Fastblasterboy's Avatar
Is your plug fouled? Its too hard to tell what your problem is.... not enough information.
Old Jan 8, 2006 | 09:42 PM
fastestkidaround's Avatar
I agree with fastblasterboy. Have you ever changed your spark plug. If not it is probably used up. Try to put a new plug in it then try to start it it might just be a lot easier.
Old Jan 10, 2006 | 08:05 PM
Storj's Avatar
Pull the plug and check if it is fouled. Its fouled if it is oily and wet. You can either clean it or buy a new one. Also chek your compression it might be time for a rebuild.
MikeyBoyesq
Nov 27, 2020 02:44 PM
wildbill59
Jun 20, 2015 02:26 PM
wbfjim
Jun 8, 2015 06:20 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
