Banshee Coolhead
Just went on my last trip to the dunes for this season and I am ready to get some new mods for my Banshee. Ive got the t5s and the carb mounted K&N's. Ive been reading some of the posts and am thinking a coolhead and maybe some V Force reeds might be something I would want to do. What kind of coolhead should I get and will these mods make alot of difference. Dont know too much about two strokes so any info from you banshee guys would help. Oh, I ride in Glamis so pretty much sea level, what domes should I run if I dont want to use race gas, or does race gas make a ton of difference, Thanks for your help
Noss Machine makes a good aftermarket head for the Banshee. You can basically just bolt it on and go ride. With the Pro-Design you have to change studs in the cylinders. I would probably go with a 20cc dome unless you have some port work. You can still run pump gas (91 or 93 octane fuel) with the 20cc domes. The V-Force reeds do make a difference, mostly in the throttle response and mid-range pull.
Noss machine, pro design, mod quad, tony dukas racing, trinity, and probily some others. The noss machine head is the way to go scince you can use your stock head studs with it. Check out alba, they have some there too.
not to steal this topic but i just got a 2001 banshee a peice of the piston broke off and hit the dome of the cool head not sure what kind of cool head it is so i cant order a ner dome. on top of the head it just has stage 4 can anyone tell me who makes it thanks
