6 degree key/spring
Old Jan 12, 2006 | 11:33 PM
shortyno11's Avatar
Default 6 degree key
i have a kfx 700 and was wondering what is better the 6 degree offset timing key, or a new clutch spring, or both.
i want to get one or both of them, so can anybody tell me anything about these items?
Old Jan 14, 2006 | 05:37 PM
sammydogs64's Avatar
Default 6 degree key/spring
The 6 degree is going to enhance your performace dramtically. I have the Dyna CDI which effectively does the same thing and the performance is amazing. I changed the springs as well to optimize my clutching for my large tires and riding style.
Springs are cheap, don't go with one of those High Lifter kits clutch kits, Buy a black secondary and a White or bright green primary spring.
I don't know how difficult it is changing the Key but I can tell you the Dyna CDI is plug and play
Old Jan 14, 2006 | 05:53 PM
razzergreen's Avatar
The key is easy to put in as long as you dont mind opening up the side of the motor. You will need a puller , prob. from a dealer or you can order on line. Takes about an hour to do, but be sure to seal the case side up good.
Old Jan 15, 2006 | 12:32 AM
shortyno11's Avatar
so the 6 degree would be a lot better? does it come with instructions?
Old Jan 15, 2006 | 01:30 PM
mawcus's Avatar
gO TO KAWIERIDER FORUM AND PM VENFORCER, HE SELLS THEM, THEN DO A SEARCH FOR THE STEP BY STEP INSTRUCTIONS.aLSO 700V.com HAS HELPFUL INFO.
Old Jan 15, 2006 | 04:41 PM
shortyno11's Avatar
thanks for the info guys. looks like the degree key is easy to install, and its cheap.
Old Jan 15, 2006 | 06:28 PM
mentalmojave's Avatar
venforcer sells them for $20 shipped and he includes instructions with them.
Old Jan 15, 2006 | 09:24 PM
shortyno11's Avatar
sweet!
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 2, 2015 11:15 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
