185 honda
Old Jan 17, 2006 | 06:34 PM
redneckfromnb's Avatar
Default 185 honda
i got a 185 honda with approximatly 40 hours on a top end rebuild.i finally got it to stop smoking but it still fouls the plug with only an hours run,some times after 2 or3 hours i need a new plug. any ideas?
Old Jan 18, 2006 | 04:17 PM
HondaAtcRoxz's Avatar
Default 185 honda
My guess would be that you might be running too rich and fouling out your plugs.
Old Jan 18, 2006 | 07:38 PM
Default 185 honda
the carb center needle is on the 2nd groove from the top,should i go up any further?what else could be done?
Old Jan 18, 2006 | 10:45 PM
Default 185 honda
You could try to put it at the top and see if it runs anybetter or longer but i wouldnt run it extreamly hard cause running it lean could hurt the valves. If it runs good and doesnt foul your plug anymore i would say your good to go.
How did you get it to quit smoking anyways???
What color was the smoke???
Old Jan 19, 2006 | 06:15 AM
Default 185 honda
it just seemed to stop on its own.it still smokes a little,not as bad as it did.
Old Jan 19, 2006 | 05:45 PM
Default 185 honda
Any new news???
Old Jan 19, 2006 | 11:58 PM
Default 185 honda
What color is the smoke???
Old Jan 20, 2006 | 06:43 AM
Default 185 honda
the smoke is a blue gray color,not sure why it stopped,i put the needle on the very top groove and it revs high,cant idle it down with the idle screw,any ideas?
Old Jan 20, 2006 | 01:10 PM
Default 185 honda
well since the smoke is blue that means your burning oil. thats what is fouling your plug out. move the clip back to where it was. Sence you just got it, it probibly smoked before the valve broke if you bore it out like OLDKAWI said it will probibly stop fowling out your plug. or hone it out and get new rings. that should stop the fowling.
Old Jan 21, 2006 | 07:29 PM
1988TRX250R's Avatar
Default 185 honda
have worked on many old atc's in the shop. even after cleaning the carb and replacing all internal parts, some machines would still foul plugs. on a couple of machines we replaced the carb w/ a brand new one and had no plug fouling since. not exactly sure whats wrong w/ old carb but a new carb worked. this won't help you though if you are burning oil like your describing but just something we found that worked on a strong motor.
