Yamaha Rhino Failure
Old Jan 18, 2006 | 05:17 PM
duckhunter1's Avatar
Default Yamaha Rhino Failure
Bought a Rhino 15 months ago and the Stator assembly went out and the cost for replacement apr. 700.00, Yamaha would not help even though this should not happen according to the dealer, only on older motorcycles do they see this problem. So if you are looking at a Rhino, BEWARE!!!!!!!!!!!!!!!!! Yamaha will not help you on defective parts after the warranty. Hindsight is 20/20, should have bouhgt the Polaris
Old Jan 19, 2006 | 04:44 PM
Bluethumb's Avatar
What was the reason for failure on it? Were you running too much load, bad regulator, short cct??? This is the first time I've heard of a stator failure on ANY RUV, or ATV for that matter. Maybe take it to a motor winding shop and see what it would cost to have it rewound. They could probably use a little heavier wire to give you more power output as well. For $700, it's worth looking into anyway0.
Old Jan 19, 2006 | 06:56 PM
Too late, needed it back quickly(only 1 week left in duck season) and told dealer to fix it but thanks for the idea. I have no idea what the cause would be, never carry heavy loads except for my big self, another rider and guns. That is exactly why Yamaha should have helped with the cost , something was obviously defective.
Old Jan 19, 2006 | 07:38 PM
MikeM's Avatar
He's asking how many electrical accessories you have, like a light rack, GPS, heater, winch, back-up light, heater, TV, stereo, blender etc.... if you do have this stuff, was it wired correctly
Old Jan 19, 2006 | 09:24 PM
I have a winch, couple of marine lights on the front, and the digital display, haven't used the winch but twice and the lights rarely. The dealership wired all but the lights which are wired directly to the battery and mounted on the front bumper. I am no mechanic obviously nor electrician but I would hope this would not over load the stator assembly
Old Jan 20, 2006 | 07:21 AM
garyc660R's Avatar
You need to look into how many watts those lights are drawing and check on the wattage load limit for your stator.
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
black_thunder
Sep 22, 2015 07:59 PM
Sep 17, 2015 03:06 AM
greg74
Sep 10, 2015 07:58 AM
