Lakota 300 jetting help please
Old Jan 24, 2006 | 05:37 AM
BuzzAU's Avatar
Default Lakota 300 jetting help please
Hi my name is Mark and live in Australia. I recently aquired a Lakota 300 which that had been imported from the USA.
I am having problems with the jetting. The bike apparently came from a high altitude and it does not run correctly where i am at sea level.
What is the standard jetting(pilot and main) for these machines so i can get it back to base settings?
Old Jan 24, 2006 | 06:06 PM
rolsmojave3's Avatar
Welcome to the forums, I dont' know for the lakota but I'm bumpin this up so holeshotz or V-unit will see the post
later
Old Jan 25, 2006 | 07:34 AM
holeshotz8436's Avatar
yes welcome......the stock jet sizes are a #145 main, #58 pilot and the air mix screw 2 turns out but thats just a basiline that kawie puts in all the lakotas so if thats what you have and your jetting is off you will have to play with the main jets and shim your needle untill you get it right.......the easyst thing to do for you would probally be to purchace a dyno jet kit because it gives you guidelines for your elevation and it comes with a ajustable needle jet........hope this helps.....
Old Jan 25, 2006 | 11:40 PM
BuzzAU's Avatar
Thanks but got it sorted. the pilot jet was gummed up. runs fine now. Holeshotz i have bought a dynajet kit and i have now installed it. Another thing that 58 jet is actually the starter jet not the pilot.
I have put the 134 from the dj kit in needle in 3rd clip and it has a 38 pilot
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
