How to fix a noisy steering shaft?
Old Jan 25, 2006 | 11:00 AM
kj330's Avatar
Default How to fix a noisy steering shaft?
This is on my wifes ATP 330. We went through some water that was deeper than we thought(almost up to the rack on the front). And ever since it is squeking and is a little hard to steer. I tried the basics (WD-40, OIL ) Any suggestions??????????
I went through on my 700 and I have no problems. That machine is snorkled up above the front boxes and she still got water in the clutch.
Please help...
Old Jan 25, 2006 | 12:34 PM
floodrunner's Avatar
Ours usually start squeaking from dusty conditions, not from water. My fix……. I wear ear buds when I ride so I just crank up the tunes.
Old Jan 25, 2006 | 01:49 PM
kj330's Avatar
Thanks floodrunner but that is not the fix I am looking for.[img]i/expressions/face-icon-small-smile.gif[/img] It is not the noise so much I am worried about but the hard steering....
Old Jan 25, 2006 | 07:46 PM
Yeah, I guess I guessed that, sorry.
Not to sound too basic but when you move your handlebars they in turn move a lot of other stuff. That squeak could be coming from the stem, the tie rod ends the strut housing the strut tower the front springs……… Get the front end in the air, have someone move the handlebars back and forth and listen for the squeak. Try to narrow it down. You can get a grease needle to inject lube into your tie rod end boots. I’d spray the springs and everything under there liberally with WD. If it doesn’t cure the squeak the mud will come off easier, you sure won’t hurt anything.
Old Jan 26, 2006 | 09:34 AM
kj330's Avatar
Ya that is todays job... Thanks Flood
Old Jan 26, 2006 | 06:49 PM
kj330's Avatar
Fixed thanks floodrunner. it was in need of some good old lube[img]i/expressions/face-icon-small-smile.gif[/img]
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Chasso
Sep 19, 2015 03:06 AM
Logan Collins
Sep 5, 2015 08:03 PM
