Horse power
I got this off of atvconnection forum by 99mudking
"Here's a list i've been compliling for a LONG time (some may be off a little, but most i have checked with more than one source):
Arctic Cat (suzuki engines, except the kawi-powered V2, and arctic cat's own H1):
500: (2003 and up have slightly detuned Vinson engine): 32hp @7000rpm, 34 lb-ft torque at 3500rpm (pre-03 had 28/30.5)
300: 14hp
650 V2: (close to prarie 650)
Bombardier (Rotax engines):
Outty 800: 62hp @ ? rpm, 52tq @ 5500rpm
Quest 650: 42hp
Outty 400: 28hp
Honda:
Rincon 650: 39hp
Foreman 450: 24hp
TRX 300: 16hp
400EX: 27hp
300EX: 21hp
TRX450R: 42hp (questionable)
Kawaski:
BF750: 51hp
Prarie 700: 46hp
Prarie 650: 42hp
V-Force 700: 51hp
Polaris:
SP700: 45hp
SP500: 30hp
SP500 HO: 38hp (same as scrambler 500)
SP800: 55hp/50tq
Suzuki:
KQ700: 49hp
KQ300: 14hp
LT500: 53hp
Eiger 400: 25hp
Vinson 500: 34hp
Yamaha:
Grizz 660: 42hp/35tq
Warrior/Wolverine 350: 18hp
These are brake hp ratings (BHP) from the factory... there will some variances from quad to quad (usually within 1-2 hp/tq of the above ratings). Hope this helps someone out there.... "
This part from Arcticchat from green goblin
Alot of new quads coming out. Here's too name a few.....Bomber 800cc HO, Bomber 650cc HO, Rincon 775cc etc....but how do they really compare to the V2, H1, Brute 750, P800, KQ700 in terms of gross HP at engine by weight stock.
Though I would start a list, but will need some help.
Outy800, 62 hp at 639 lbs = 0.097 hp per lb
Outy650, ?hp at 649 lbs
BF750, 51 hp at 600 lbs = 0.085 hp per lb
P700, 46 hp at 600 lbs = 0.077 hp per lb
P650, 42 hp at 600 lbs = 0.070 hp per lb
AC650 V2 SE, 42 hp at 711 lbs = 0.069 hp per lb
AC650 H1 SE, ?hp at 693 lbs
AC700 EFI SE, 49hp at 694 lbs = 0.071 hp per lb
Rincon650, 39hp at 600 lbs = 0.065 hp per lb
Rincon700, ?hp at 600 lbs
SP800, 55 hp at 770 lbs = 0.071 hp per lb
SP700, 45 hp at 770 lbs = 0.058 hp per lb
KQ700, 49 hp at 603 lbs = 0.081 hp per lb
Grizz660, 42 hp at 600 lbs = 0.070 hp per lb
300: 14hp
Quest 650: 42hp
Outty 400: 28hp
Honda:
Rincon 650: 39hp
Foreman 450: 24hp
TRX 300: 16hp
400EX: 27hp
300EX: 21hp
Kawaski:
BF750: 51hp
Prarie 700: 46hp
Prarie 650: 42hp
V-Force 700: 51hp
Polaris:
SP700: 45hp
SP500: 30hp
SP800: 55hp/50tq
Suzuki:
KQ700: 49hp
KQ300: 14hp
LT500: 53hp
Eiger 400: 25hp
Vinson 500: 34hp
Yamaha:
I think the power to weight ratio is the most impressive part. all the engines are for the most part the same hp within 1 or 2 for the cc size so it the actual weight of the quad that makes the biggest difference.
Power to weight ratio is important. But it also depends on what the power curve looks like. If the power curve is flat thats good. If the power curve is spikey thats bad for regular riding and good for racing.
I actually almost bought one before I got the cat. The price held me to cat along with accessory racks, ground clearance, and style. But I have heard the bom ihas a good reputation for workmanship, durabily, and reliability
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Elkaholic
Sep 6, 2015 02:44 PM
