Sunl-70 HELP!!!!!!!
Old Jan 26, 2006 | 03:55 AM
HTELectrical's Avatar
Default Sunl-70 HELP!!!!!!!
I screwed up literally. Not paying attention I removed the wrong bolt when changing the oil. The bolt on the left side of the engine has a large spring and a cylinder in it that popped out. Which way does the cylinder and spring go back in???????
Old Jan 26, 2006 | 05:46 PM
Kazooooma's Avatar
I've done that not once but twice, and I'll probably do it the next time as well. Can't tell you from memory which way I put it back in, but the engine has survived so I must have gotten it right. Seems like I studied the ends of the plunger for a while, then it finally made sense which end went against the spring and which into the engine.
