I can't start my Raptor unless it's in nuetral. ?
I just took the e-brake off my Raptor, and , I can only start it in nuetral. I did take the lever assembly off and unplugged the wires. Is there any way I can fix this problem and be able to start it in any gear without putting the stock lever assembly back on?
there are 2 plugs going into the factor perch, one needs to be wired together and the other apart (I think thats it, or both apart) I just put a cr 250 perch and lever on mine. one lets the bike start in and gear without the clutch when bypassed. the other keeps the rev limiter from kicking in (from when the emergency brake would be enguaged)
Ya I put a cr perch and lever on mine and it did the same thing! What you need to do is plug the cable with the 2 plugs on it (not the white plug) back together and just zip tye the cable under your plastic. You'll need to pop the cable out of your old perch and just plug it back in with the wires under the front plastic. If you have any questions just e-mail me back and I'll try to help you out.
