how do i break in a 2006 trx250ex
Old Jan 28, 2006 | 11:57 AM
warriorboy22's Avatar
Default how do i break in a 2006 trx250ex
My friend is getting his next week and he dont know how to break in an engine and i never broke on in befor so can someone help step by step.
Old Jan 28, 2006 | 01:16 PM
quad2xtreme's Avatar
two ways you can go:
1) Break it in easy according to the manufacturer
2) Warm it up (make sure it is warmed up for at least 3-4 minutes) then run the **** out of it. You will get some links from others on how this seats the piston rings better.
/Jon
Old Jan 28, 2006 | 02:16 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Break it in, like you're gonna ride it!
Old Jan 28, 2006 | 10:15 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
http://www.mototuneusa.com/break_in_secrets.htm
Do an early oil change, like at 2 hrs. Honda's are pretty clean from the factory, but still do an oil change to be sure you get out any metal filings. Plus, you don't have an oil filter, so all the more reason. Use Honda GN4 oil during break-in, then I suggest switching to Maxima Extra oil.
Old Jan 29, 2006 | 12:13 AM
CaRider67's Avatar
Read with an open mind and remember the factory red lines each engine in order to pass quality control. I'd also suggest changing the oil and filter after the first real ride then switch to synthetic.
Old Jan 29, 2006 | 05:36 AM
Red Rider
I use the motoman method, but I also "heat cycle" my engines. That is, I cool the engine completely between each riding session during break-in. At first, I start out with short rides, then increase the time as break-in continues.
Old Jan 29, 2006 | 04:37 PM
WVGREEN450's Avatar
no don't use synthetic. Honda Oil is the best for a Honda ATV! the tranny does NOT use any synthetics! you will make a clutch and tranny slip right now with a synthetic oil! USE HONDA ATV OIL ALWAYS!
Old Jan 29, 2006 | 06:14 PM
Red Rider
No way.......it's nothing but a myth! Synthetics are just fine in these machines, as long as it is a Motorcycle Specific oil that is API SG/JASO MA (what your owners manual recommends!). I don't doubt that some folks may have had problems if they have run "car" oils that are not JASO MA, but that applies for petroleum oils as well as synthetics. That is where these urban legends get started............
Been running Maxima Extra for years and years......absolutely no problems. My motors and clutches last forever, and a day.
Old Jan 29, 2006 | 10:21 PM
TheTurtle's Avatar
the maxima pure synthetic is better than any honda oil. i never ran anything but in my machines. as far as break-in. warm it up for a few 3-5 mins depending on the daytime temp. i always go by the oil cooler. when that is warmed significantly i know the motor is up to temp. then take it out and ride it like you stole it for 45 mins. drain the oil after she cools flush and fill it, then ride the rest of the day as long as possible. drain the oil again flush and fill, and ur good to go.
honestly they 250ex doesnt need a breakin. they are TANKS. i will say it time and time again. my friend had one and beat the hell out of it for 3 years, it always fired right up, never left him stranded, and it pulled plenty of yamahas back to camp. just do regualr oil changes being that it is air cooled and she will last forever.
Old Jan 29, 2006 | 10:31 PM
Doctorturbo's Avatar
GOT BOOST!
Every single aftermarket cam maker we use in our race cars say:
DO NOT USE SYNTHETIC OIL TO BREAK IN OUR CAM
That is no myth.
Since I have not built a race engine in a long time I checked their web site to see if things have changed. They haven't. They still don't recomend using syn oil with a new cam.
Seems strange to me, but these people do A LOT of R&D and know what they are talking about.
After break-in you can use dino or syn in your machine. It's up to you.
