Aftermarket yzf 450 06'
just bought the 06 450..and i love it..im going to go with the dr. d spark arrestor set up for exhaust ....but what about the rest..i've always delt w/ two strokes..what is the best way to go with hooking it up as far as facil and motor work..any input would be good..
The principal is the same, more air in more air out. Get a Pro Deisgn intake, leave the lid off the box. Get a full header and exhaust, rejet the carb. Try it out and see what ya think. Some people have reported that retarding the exhaust cam one tooth is a free upgrade.
If thats not enough, look for a 500cc big bore kit with even higher compression than the already high stock piston, cams, big valves with heavy springs, get the head ported.
Moddifying a 4 stroke will cost a ton of money when compared to a 2 stroke. Before i got my 700 Raptor, id been riding 2 strokes for years as well. I was shocked when I saw the prices of things.
Are you riding in Glamis or Ocotillo? If its just Ocotillo, im sure the intake\exhaust\rejet will be fine. Go to Glamis, and you will probably want more.
I will be doing mostly ocotillo....and a few trips to glamis and superstition or gordons, but 85% ocotillo....alright i will just stick to what i have now..and what i iwll be doing soon, the pipe and rejet...thanks....dang were neighbors..o'side and fallbrook
You dont always have to break the bank to amke your 4-stroke faster. Do the free cammod first, and that will give you another couple "free' horsepower. Get a pipe and intake, and jet it. Thus far with those mods, unless you go wild with some crazy exhaust, you should be well under what the shee is going to cost to do the same. I think what people get frustrated with is the internal motor stuff, as there is a lot going on. A piston for the yfz is going to run you almost $200. Cams can get really spendy, as the latest crower gen III is running about $400, for just the intake cam.
I wil very strongly agree that a 4-stroke does cost money to "motor" upgrade. But as far as normal mods, the 4-stroke in my experience is actually cheaper to get going. Especially on my old banshee, there is two of everything! Banshee's can still get expensive to work on too!!!!!!!!
Originally posted by: sittingdpbplyr63
you say just do some easy upgrades, but what does that consist of(besides a pipe, intake and jet)
My quad was dynoed with the below mods and its putting out mid 50's.
If you want more than that, your going to have to bore it or turbo it or something! Usually the big bores and strokers arnt making that muhc more peak power, but a butt load of bottom and mid!
Good luck!
