honda quad seized up
Old Feb 3, 2006 | 07:52 PM
pugads650's Avatar
Default trx70 stuck
i just got back from christmas vacation i was away for about a month and 2 weeks well anyways i went to start up my bikes up and my little trx70 will turn on but the rear wheels are stuck they will rotate about 1/8 of a turn and stop. i turned the bike on and put it in to gear and tried to move but it will not move i checked the brake to make sure the problem wasnt the breaks but no luck what could be causing this.
Old Feb 3, 2006 | 09:15 PM
pugads650's Avatar
Default honda quad seized up
anybody
Old Feb 3, 2006 | 09:33 PM
TractorPacker's Avatar
Do you have a balloon?
Must be in the axle bearings. I don't know what the carrier and awingarm look like on the 70, though. Is it chain driven?
Old Feb 3, 2006 | 09:52 PM
Kodiak660's Avatar
Could be a rusted chain.........how does the chain and sprockets look?
Old Feb 3, 2006 | 10:15 PM
pugads650's Avatar
it does have a chain and a drum break in the back how would it cost to have the axle bearing fixed
Old Feb 3, 2006 | 10:17 PM
Kodiak660's Avatar
Pop the chain off 1st and see if its the bearings or not.
Old Feb 4, 2006 | 01:59 AM
That would be my first suggestion, also. See if its the axle, or the trannie.
Old Feb 4, 2006 | 09:56 AM
MikeM's Avatar
a rusted chain, that's funny. spray it with a little WD40 or should he take it off?
drum brake or axle bearing would be my guess, probably the drum. sometimes the spring that holds the shoes together breaks. getting the drum off can be a mother if this is the problem.
NICE GN, is that crankshaft or rear wheel HP?
Old Feb 4, 2006 | 12:23 PM
Harw's Avatar
The brake drum on the 70's are not sealed. One of the linings came off the brake shoe and is wraped under the other shoe. That happens alot to the 70's.
Old Feb 4, 2006 | 08:40 PM
pugads650's Avatar
i just took off the 2 metal shields and took off the chain but the wheels are still stuck so it might be the bearing or drum i cant get the drum off is there anyinstruction on how to get it off thanks
john
