Can't get the DS started
Old Feb 4, 2006 | 02:34 AM
Bombar818's Avatar
Default Can't get the DS started
The DS has been sitting for about 8 months now. I changed the spark plugs, oil, oil filter, gas, air filter and cleaned the carb and all of the jets within the carb. I cleaned the jets with a needle and air compresor. Carb is as clean as a whistle. When I spray gas into the carb it fires right up and I can keep it running as long as I shoot gas into the carb. I checked the fuel line and it flows fine. Where is my problem?
Old Feb 4, 2006 | 09:31 AM
cpaul's Avatar
There has to be blockage in the carb somewhere.
Start from beginning, if you pull fuel line off carb and fuel comes out, you know the supply is there.
If it is, then follow the circuit of flow through the carb.
Take you time, you will find the problem.
Good luck.
Old Feb 4, 2006 | 11:53 AM
smb05's Avatar
Make sure the carb bowl has fuel in it, also recheck your float, needle and seat for proper level and adjustment.
Good luck
SB.
Old Feb 4, 2006 | 12:11 PM
Eaglecollector's Avatar
Float level should be 10mm.
Old Feb 4, 2006 | 01:59 PM
Bombar818's Avatar
Yeah, the supply of gas is getting there but it's getting blocked some where. I tried playing with the floats but never had experience with the floats and I feel that the problem is in that area. Thanks for the input guys.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
