JETTING QUESTIONS!!!!!
Old Feb 11, 2006 | 11:55 PM
marlboro's Avatar
Default JETTING QUESTIONS!!!!!
this might sound like a stupid question, but do u have to re-jet ur carb if u buy a slip-on exhaust, or just for a full system?....or what?...
Old Feb 12, 2006 | 12:38 AM
recon99's Avatar
This depends on a lot of things, but usually you should rejet. If it's already jetted a little on the rich side you might be ok, but here's the way I see things:
To get the most power out of your quad you need the fuel/air ratio to be perfect or close to it. If you allow your engine to pass more air through, you also need to add more fuel to keep the ratio on target. If you're going to spend that much $$$ on exhaust to get power gains, why not spend a few hours jetting it right and get the most power out of it?
Old Feb 12, 2006 | 12:52 AM
marlboro's Avatar
thansk, so if i was to order a hmf slip on, which i sorta want somtin that is loud!!!...which alot of ppl always complain about to loud of pipes, but i thank the hmf would eb preety loud, but geeting back to the point, when i order my exhaust, will the local dealer jett it for me?......plz reply back!!!!
Old Feb 12, 2006 | 01:04 AM
recon99's Avatar
If the dealer repairs quads (which most dealers do) they will jet it for you, but it will be expensive. It cost me $150 to get mine jetted the first time. After paying that bill I learned how to do my own jetting real quick. It's not too hard to do. It's just a little time consuming, but it's something you should know anyways. When the weather gets colder or warmer you should rejet anyways because of the changing air densities.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
