puffin threw carb on a 02 mojave
ok i just got this mojo back together a few days ago..( top end swap)..well put the carb on and got alot of gas from the overflow tube and the back of the carb was pushin gas out ..well i just wanted to see if it would start.. well i turned the gas off and kicked a few times and it started full choke (really cold that day) and alil throttle. would run for a few seconds and shut down .. well when it would shut down id get alil puff threw the carb?...now could it be b.c carb is messed up ? or timing? if u think its timing can u lead me in the right direction to see if i set the timing correct
thanks
thanks
GregM
Mar 6, 2018 06:53 AM
Mojave250A
Jul 11, 2015 10:38 AM
