how do i add a 4 pin trailer plug
Old Feb 16, 2006 | 10:22 PM
jonnyyellow's Avatar
Default how do i add a 4 pin trailer plug
well, i've always wanted to add a 4 pin trailer put to my quad.. i just dont know what wire to splice into..
i only need lights and brake lights...
any help would be appreciated
oh also its for a rancher
Old Feb 16, 2006 | 11:39 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Since you don't have turn signals on the Rancher you'd be running it more like a three-pin, but it will still work. You're only going to get trailer running lights and brake lights.
Connect the white wire from the 4 pin harness to a good clean ground on the quad. Brown wire goes to the hot wire for the rear light. Twist the green and yellow wires together and hook them up to the hot wire for the brakes. You may need a meter or a test lamp to find the correct wires.
Jaybee
Old Feb 17, 2006 | 01:29 AM
quicksilver's Avatar
Ok, the above post is correct, but you should actually use relays to run the trailer lights. Otherwise you'll pull all the amperage through your brake lamp circuit and tail lamp cicuit and blow a fuse.
Old Feb 17, 2006 | 08:00 AM
waht type of relays?
yeah i only need noremal lights and brake lights
thanks for the info.
Hankey Pankey
May 1, 2018 01:33 PM
Divergent12
Dec 30, 2017 08:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
