my heated grips dont work grrrr
Old Feb 17, 2006 | 11:28 PM
maddmudder13's Avatar
Default my heated grips dont work grrrr
while plowing the little snow we got yesterday i figured out that my heated grips dont work. the light comes on but they just dont heat up. i put the battery charger on it and then i fliped the swith from off to high to low. when i fliped it to low the battery charger boged some but on high it didnt bog at all any ideas?
Old Feb 18, 2006 | 06:49 AM
2502500's Avatar
buy a good pair of mittens
Old Feb 18, 2006 | 10:21 AM
500rubicon's Avatar
sounds like the same problem i had but on my low didn`t even work.You might want to check the wires on the high side, or if u have the switch you can just get a new one.But you should buy one from an auto parts store they are much cheaper but might require a little modifing so the wires will got on it.
Old Feb 18, 2006 | 03:49 PM
thats what i was sort of thinking, a bad switch. would it work if i just cut out the regular switch and wire in a rocker switch or something like that? so that the wires from the battery directly go to the grips or would that be to many volts going to them?
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Scottma518
Jul 10, 2015 12:42 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
