2001 Honda Rancher TRX350ES starter
Old Feb 19, 2006 | 04:26 PM
tammyt's Avatar
Default 2001 Honda Rancher TRX350ES starter
My electric start has been working fine until yesterday. It has been sitting for about 4 weeks, when I tried to start it yesterday, it would not start using the electric start. I had to use the crankcord. It started fine with the cord, but I could not change gears. Any ideas what could be going on with the 2001 Honda Rancher TRX350ES?
Old Feb 19, 2006 | 04:47 PM
quicksilver's Avatar
did u happen to see if the gear indicator says "N" for neutral? If the ECM doesnt see neutral, the electric start wont work. If the bike is indeed in neutral but the gear indicator doesnt show it, maybe you have a bad gear indicator sensor.
Old Feb 19, 2006 | 04:50 PM
tammyt's Avatar
It did show that it was in Neutral. I wondered if it might have something to do with the weather being so cold.
Old Feb 19, 2006 | 05:40 PM
muddirtsand's Avatar
BATTERY
Old Feb 19, 2006 | 06:23 PM
tammyt's Avatar
Thanks but the battery tested good. Any more ideas? Any and all suggestions are welcome.
Old Feb 19, 2006 | 08:49 PM
when you tried to start it.....did the starter click at all? did it actually engage and try to turn? Or did the starter just free-wheel and not turn the engine?
Old Feb 20, 2006 | 01:44 AM
hondabuster's Avatar
The battery tested good under a load?
Will the starter work fine, once the motor is up to temp?
Check the connections on the battery terminals, they may be oxidized or cororded.
Old Feb 20, 2006 | 04:16 PM
DocHoliday31's Avatar
It sounds like a electrical problem, It cranked by pull starting=battery good. So mark that off list. In neutral = ECM good. I would try checking all fuses, Then make sure you got power to starter, (test light-ohm meter). But not shifting, (ESP). Which is a Electrical Shift Program. Make sure you don't have water (sweat-from cold weather) in fuse box. That happened once on the trail (of course it was water from playing) but is shorted a couple of fuses out and had to replace them, they blew right out. Had to get some air and blow the fuse box out. Then replace fuses.
Good Luck!![img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 20, 2006 | 09:43 PM
Gimpster's Avatar
2001 Ranchers are fun in the fact that it does not have diagnostic type ECM. Most common troubles I have serviced on this year of a rancher are related to the 2 topics you have mentioned. Your starter brushes are eather worn or simply stuck. depress the starter button and lighty tap on the starter motor ( don't beat on it or the fields may be damaged ). If the starter spins over when tapped on, the starter brush plate and starter brush are worn. Do not keep tapping on the starter to start the unit as armeture damage will result from the worn brushes, arcing, on the armeture. If it must be tapped to turn the engine over, service the starter with a new brush plate and brush.
The electric shift problem is probably the shift angle sensor and or connection, located on the lower front cover of the engine ( under a tin cover held on with 2 bolts ). Most likely if the sensor has never been replaced, it is faulty. If the sensor is removed and it says "Mexico" on it, replace it (remember the o-ring ). Also if the battery is low it may amplify the shift problem. Cold weather does seem to bring on ground troubles. Since the '01 Rancher does not bring up diagnostics on the instrument cluster, Chasing shift problems is more difficult. In my experiences with trouble-shooting this type of system. the problem is usually found at the angle sensor connector, or the sensor itself. (also make sure your idle is not too high or the choke is partially on when trying to shift )
Hope this helps you
----- Gregg -----
Old Jan 3, 2011 | 10:45 AM
WBrett's Avatar
Default Having same starting issue with 2004 Honda Rancher TRX350ES
Gimpster, I see your note.....the starter brush plate and starter brush are worn. Do not keep tapping on the starter to start the unit as armeture damage will result from the worn brushes, arcing, on the armeture. If it must be tapped to turn the engine over, service the starter with a new brush plate and brush.
Gentle tap on starter has worked but now want to correct worn out parts. Do you have written procedure/diagrams to replace brushes and brush plate.
Thanks.
