Rancher Vibration Noise
Old Feb 19, 2006 | 09:25 PM
DoubleR's Avatar
Default Rancher Vibration Noise
I just bought an 04 Rancher. The valves needed adjusting so I did that today and now I notice a vibration noise when the rpm's are up, it almost sounds like a heat shield or skid plate loose noise, but I check all that and it's still their. Any suggestions?
Old Feb 20, 2006 | 03:53 PM
BayouRunner's Avatar
Don't know if this is your problem, i have an 05 Foreman and noticed a rattle when the engine would warm up. Turns out is was a loose baffle in the muffler, it was under warranty and the dealer fixed it.
Old Feb 20, 2006 | 04:22 PM
DocHoliday31's Avatar
My Rancher mad a similiar noise, I later found the heat shield on the exhaust was vibrating A few shims and all good. A good way to check is while riding, Put your foot on the shield, see if it stops?
Good Luck!!
Old Feb 20, 2006 | 07:59 PM
DoubleR's Avatar
I found the problem today it was the heat shield for the pipe at the bend right above where you put oil in the motor. The nut had come off, I replaced it and fixed the noise.
Thanks
Old Feb 21, 2006 | 05:56 PM
Glad it was nothing major!
Johnny Mac
Aug 15, 2019 03:13 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Clint Russell
Sep 25, 2015 03:20 PM
