Spark Arrestor for Raptor 700
Old Feb 24, 2006 | 11:23 AM
eadwiggi's Avatar
Default Spark Arrestor for Raptor 700
How do you remove the spark arrestor? Is it pretty easy? What are the advantages and disadvantages of taking it out?
Old Feb 24, 2006 | 02:07 PM
GreenBeast's Avatar
Very easy to remove, there is one hex head screw in the back end of your muffler on the bottom. Take it out, you might need a pair of pliers to pull out, and twist the exhaust tip to work it loose, then just pull it out. Once you get it out you'll be able to see the advantage of removing it. It is extremely restrictive, eating up a lot of your power. Plus is sounds a lot better without it. There really isn't any disadvantages to having it out, unless you ride in parks that require one. If so there is an aftermarket type arrestor, i'm not sure who makes it, but I believe you can get it at rockymountainatv .com. It is a lot less restrictive than the stock version. Have fun.
Old Mar 4, 2006 | 01:23 AM
smuznu's Avatar
I'm having a hell of a time getting mine out.......Is the entire end supposed to some off or just the small 3/4" diameter tip? Can you send me a quick picture?
I'd appreciate it.
Thanks,
Smuznu
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
