ice racing
Old Feb 24, 2006 | 10:04 PM
FrostyLemon's Avatar
Default ice racing
i want to try ice and tt racing but i dont have the money to lower the quad so does any one no a cheep way to lower it. O and its a 400ex
Old Feb 25, 2006 | 09:11 PM
2000scrammy's Avatar
Default ice racing
Why do you want to lower it in the first place? Are you just going to lower it for stability reasons and to keep all four tires on the surface. IF that's why I would suggest just getting wheel spacers or wider a-arms for the front-end. You can get a longer axle for the rear too. However, while wheel spacers are not that bad a-arms and an azle probably won't be cheap at all. You could also look for a sway bar. This will help even out the inside shocks with the outside when turing and will help to reduce the amount of lean and should help keep you stabile and on the ground.
Old Feb 27, 2006 | 12:14 PM
Dwags's Avatar
Default ice racing
anti-sway bar is good but there is no exchange for being low to get your center of gravity down. if you are a good metal faber you can make a redneck lowering kit but i would have to say just save money and get lower and wider is also better but lowe the better
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
