mojave reverse problems
Old Feb 25, 2006 | 12:05 AM
Hainitracing's Avatar
Default mojave reverse problems
i have a 02 mojo...and i can shift from 1st to reverse without using the switch...i did take the reverse cover off and checked it out.. i turned the switch and watched the arm move back and forth...started it up and got it to work fine..but as soon as i put the cover on it does it all over againso what u think?
Jeremy
Old Feb 27, 2006 | 09:49 AM
2000MOJAVE's Avatar
Take the cover back off, clean the area out real good and spray some good lube on it and let it keep soaking in around the shaft. I use to then spray it with white grease that you can buy at wal-mart for like $.96 Do the same thing with the reverse cable. I would do mine about every 6 months routinely just to be safe.
Reactant
Mar 30, 2022 02:08 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
